Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Well, yes, but there's no place to put the code on that page, unless
it's somehow hidden behind an image or something....?
And when I hit Add to reach the checkout cart, there's a blank
for Discount and a blank for Gift Certificate. The code doesn't
work in either of those blanks.
My python page
My ShareCG freebies
Hi,
To redeem your coupon for a 6 month subscription to Passport that you received with your purchase of Poser 7, please go to
http://www.contentparadise.com/p7passport
Add the item to your cart, enter the coupon code into the 'Coupon Code' field and hit 'Submit'. The price should then zero out. Then click on 'Checkout'.
The $10 coupon that you received with your purchase of Poser 7 is good for e frontier products and Poser Science products on ContentParadise.com
Sincerely,
efgirl
THANKS, BillyGoat! (Or 1 sh0u1d say THANKS, Bl11yG0at!)
There was an ELL in the number that I was seeing as a ONE.
After changing it to an ELL, the code worked.
Manufacturers should be required to avoid using confusible letters and
numbers when they print a serial number on paper, or else spell out
the number in some fashion. The law already requires spellouts on other
important documents like checks and contracts.
My python page
My ShareCG freebies
Okay, so I've registered at CP. I can see the name Ockham showing in the
upper left. So I click where it says to redeem the coupon that came with P7.
What next? Which number do I enter, and where? There are two numbers;
one of them begins with P7Passport, so it's presumably the entry code or
sign-up code, and the other one seems to be a $10 coupon. Where do I
put the first number? It doesn't work in the "Gift Certificate" blank, and there
isn't any other blank.
My python page
My ShareCG freebies
