would tie up my dual-core pc for perhaps 20 hours.
I should be so lucky!
It is a beautifully lit, very gentle effect. Nice.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
nice render! looks quite realistic indeed!
--- www.brycedownloads.com ---
Free downloads just for bryce
--- www.artartica.net
My personal work, right here
What I'm going to suggest may make render times unreasonable.
I can see no reflections from a ceiling so I ask does your room have a ceiling? What would happen if you added a ceiling off camera matted with a semi -transparent material to diffuse some light source(s) from above the ceiling. Again this is faking hdri
My goal here was to achieve a realistic indoor scene with Bryce 6.1. I first tried IBL using various "white blobs" to get as soft a shadowy effect as possible, but I gave that up because I could never get it to look right. Then I tried fill lights in various parts of the room to fake natural radiosity, but the shadows just looked wrong. Then I just stuck 3 lights of various softness inside the lamp shade, and tweaked each for the best effect, and this is the result. I think this is the best I can do, but I'm not satisfied. There should be more global light bouncing off the ceiling, but using ambient light or sky dome would simply wash out the nice dark shadows under the furniture. Now the sad part... this was a low rez render; if I had to render this same image for print resolution, it would tie up my dual-core pc for perhaps 20 hours.
"An Example is worth Ten Thousand Words"
