Well no one has read m y message but i have a n update for you. I discovered the problem IS the latest update of Vue 5 infininte. i uninstalled the latest update, and went back to version 5.05-02 build 275925. and the plants are now there. so it is the dumb update. However the update was awesome because for example P6 characters are imported quickly and with 5.05 it's slow. So i guess i'll have to give up on the basic plants. Where would i find free Plants to use in vue? Roses, flowers, etc etc.
From the beginning, I never had all the default plants in V5I.
I had to create in Vue a folder designing Vue own Plants folder !
Recently, Vue crashed really hard (after relaunch, it lost every manual folder of objects, plants… ), and I had to do the same manœuvre again. So I don't think it's related to a specific update.
This is something I already read a few times in forums.
Good point is : you're not alone to experience that !
Are you sure they aren't installing somewhere else? Like under C:/My documents - Vue does default to this unless you tell it otherwise.
Another thing you can do is copy the plant folder somewhere, then after you install an update, copy the contents back to it. I do the same with my other folders(the libraries I chose to keep under the main app) as well. Just to avoid such problems if they crop up :)
dlk, did you see my Pic at the beginning? I use macos x. But in the pic, that's the plants folder inside Vue folder. and all the basic plants are there, where they are supposed to be. They just dn't appear in the plant selection in the program. So my plant folder is there. with all the plants including the Alien and Edited folders. In the program only the Alien and Edited ones appear, but not the basic ones( flower, trees, fern , etc)
