Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
get free blender and load and export it .. simple ..the texture is a other story ;}
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
Quote - plugin for poser? not one that I know of.. you mean path to POVRAY which I know comes up? ignore it and save out as OBJ. you don't need Pov to run Poseray.
if i try to load it into poser as an import lwo it has a pop up that it needs a plug-in the poseray hasa weird thing as soon as it loads it tells me it cant find the disk? cant cancel it so I have to shut down poseray - does it every time - this file is not on a disk
Hi johnfields,
There are two ways. 1) In Lightwave, export your item as a Lightwave 5 file, then import Lightwave 5 file into Poser 5.
Cheers,
Patorak
I do not have lightwave - I' have to upload them for you or here's the file -
www.lwg3d.org/v3/meshes.php
Hi johnfields,
Email me at chieftanoclan7@sbcglobal.net Tell me what format you would like them in i.e obj or lightwave 5, and I'll have them right back to you.
Cheers,
Patorak
I can't recommend strongly enough that anyone who can spare the $150 or so should get Deep Exploration. It can't be beat for a good reliable format translator. I do most of my Poser modeling in Lightwave and use that to make 3ds and obj versions of the models (LW's native export doesn't always give the result I need).
One nice thing about it too is that when you convert a model and save it in another folder, it will even copy the textures to the new folder.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Attached Link: http://www.goestores.com/catalog.aspx?Merchant=righthemisphereusainc2&DeptID=229514
Where can you get Deep Exploration for $150? The Right Hemisphere website shows that the current version will be $500. That will price it way out of my league.My visual indexes of Poser
content are at http://www.sharecg.com/pf/rgagnon
If anyone can find a good place to host the Serenity model, let me know. I received permission from Sean Kennedy (the guy who made the Lighwave model) to convert it for use in Poser last year.
Some statistics:
VanishingPoint... Advanced 3D Modeling Solutions
How can I get LWO 7.5 files to work in Poser 5 tried pose ray to turn into a obj. did not work it says it needs a plug-in for poser - I can't find it anywhere
