Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Have you tried changing your mapsize? When your shadowmap is too small it may be too coarse to make accurate shadows. When I look at your settings, I see that in the ray-trace settings the blurradius is 0 and in the depthmapsettings it is 2.0 depthmapshadows are blurry by default. When you have a lot of small close objects giving shadows (like a plant) blurry shadows tend to overlap which results in darker shadows. For a crisp image it's better too use Ray-tracing, but you can first try to change the size of the shadowmap in the parametersettings.
regards,
Bopperthijs.
How big did you make the shadowmap? I would expect that you would need a value about 4096 for the shadows to get sharp.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
![file_373276.jpg](https://live.cdn.renderosity.com/forum/threads/2691436/file_373276.jpg)
I used the ivy_generator to generate the ivy in this picture When I set my shadows to Ray Trace the top picture is rendered When it is set to Depth Map the bottom picture is rendered. I have always rendered with the Depth Map and some of the other plants I use come out the same way. By looking at he pictures, can anyone tell me what I is going on? I am using Poser V6 with all the SR's installed Thank youPoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
