Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 8:42 pm)
Poser 7 now allows you to organize libraries into content collections (pg 52 in the ref manual) where you can pull things from various library categories and runtimes.
If you're looking for something to automatically sort every bit of content you install into some sort of categorical system, there isn't anything out there. Content creators have their internal system to install content (usually under their name rather than under a generic product category). Maintaining a well-organized runtime is a manual effort that you have to perform after you install products.
You can link to your old Poser runtime if you don't want to reinstall all your old content into Poser 7.
My visual indexes of Poser
content are at http://www.sharecg.com/pf/rgagnon
Using external runtimes, organized by say, figure, is a very handy way of making sure you know what goes with which figure. The only downside is the need to completely re-install everything, and the seconds lost moving between different runtimes.
Pboost can help, as it works like internal different runtimes, but it won't tell you what the poses or whatever that already installed are for.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
CR Pro
http://www.hogsoft.com/products/product_info.php?products_id=47
correct your texture and geometry references and has a tool to move your content from one runtime to another with all its associated textures and gemoetry.
My Homepage - Free stuff and Galleries
Thanks for some quick responses!
(And it would also make my life easier if Content Creators would use their names - **WITHOUT the "!" and other characters to get to the top of the $!£"ing list!)
PBoost looks handy, I'll read some more about that, it could help. CR Pro also sounds like it could save me a lot of time!
Do people feel that these programs are reasonably easy to use?
Nick
I don't find CR Pro hard to use, but it is very diffrent.
that is to say steep learning curve but once you get it, its easy to use.
After a long delay, I have fiunally moved up to Poser 7. It occured to me that this might be a good time to plan ahead and avoid the complete content mess I ended up with under poser 5!
It was just about impossible to find the poses that went with the figues, separate the mats from the actual poses. Then there was the mess of trying to find iimage file names that looked like they had been encrypted, etc, etc. It seemed like I spent more time with the windows search tool thann making the graphics...
So, can anyone recommend something to help me manage the content? Or is P7 easier in this regard? I don't mind paying extra for a useful tool, as long as I can avoid ending up in the same state as before!
All clues very gratefully receievd!
Nick
