Something fails to initialize. PErhaps there are registry entries which contain information such as the location of a Temp folder used by Bryce and located in the Bryce install folder. If it's been uninstalled, then the registry may now be pointing to a non-existing folder. Attempting to open some files that are needed when launching the app would then fail. The app might be smart enough to try and create a new Temp folder where needed, but it may fail to do so if the higher-up folder is missing too.
That's just one scenario, but you might want to check in the system registry if there's a group of entries for Bryce 6 pointing to Bryce 5 folders or the other way around. I'd completely remove the install folder and the registry, then reboot, then re-install.
Check also in Google for 0xc015002 - there's a number of people who have seen the same error before, you might find a way to fix it from there.
Uh oh :( There were explicit instructions at Daz3D about how to install Bryce6.1. It had you doing a few things that I never would have thought of and I would have messed up my install completely. I wonder if this is what happened to you. Check here and read how to install and see if you can find where it went wrong:
http://forum.daz3d.com/viewtopic.php?t=54733
I followed it to the letter and had no problems.
So I recently got the uograded version Bryce 6.1, and when I tried to install it, it asked me if I wanted to uninstall version 6.0. I did this, and for some reason it failed to install. Now, I decided that in the meantime while I tried to figure this out I would go back to version 5.5 but now it gives me an appliacation error every time I try to use it. I didn't tell the computer to uninstall version 5.5, just version 6, but for some I can't use any versions now. So I tried to reinstall version 5.5 but I get the same application error. What I think I did was, when I uninstalled version 6 I uninstalled a shared file of some sort.
Anyway, the application error # is 0xc015002. If anyone has had this problem before and knows a way to fix it please help. Otherwise I'll have to hire somebody to come and fix athe problem.
Thanks
