Bryce F.A.Q (Last Updated: 2024 Nov 26 10:16 am)
It appears that it is only the CTRL-ALT-V command by keyboard that is not doing what it should. The CTRL-ALT-C by keyboard seems to work. If I do the Material Copy by keyboard and the Material Paste by the EDIT column I get good results. I think this would show it is NOT a problem with my particular keyboard.
I have used B6.1 since the day it became available and this problem did not exist until yesterday.
Bob
Could be you have keys that are not working as they should.
and the material copied.
I exited the program...cleared my clip board and repeated the process used the ALT(Right)
If you have a desktop you should have two ALT keys... please try both the LEFT and RIGHT for testing.
check your caps lock key...? that's based on a very very dim memory of a similar problem from years and years ago....
______________________________________________________________________________________
Check out my Elemental Hexagons deck, created with Photoshop, Bryce, MojoWorld, and Poser
For years I have used Ctrl-Alt-C to copy a material from one object and a Ctrl-Alt-V to paste the material on another. Today this key command has stopped working for me and I have to resort to the commands in the Edit column. So far I have not seen evidence of any other key commands that do not work. ( bryce 6.1....Windows XP)
Any suggestions as to how I can correct the situation ?
Bob
