Sat, Jan 11, 8:37 AM CST
Subject: How to conform gun to a hand (gun harness)??
imagynart ( ) posted Fri, 06 April 2007 at 6:01 PM · edited Sat, 10 August 2024 at 6:56 AM
Does anybody have a tutorial on how to conform a gun to a hand as in harness manually or automatically? I've tried to conform a gun to a hand but it came out badly. It just took me too much of time trying to "harness" the hand to a gun. :(
Miss Nancy ( ) posted Fri, 06 April 2007 at 6:04 PM
zero figure pose (joint editor), move gun into position, make hand the parent of the gun?
vince3 ( ) posted Fri, 06 April 2007 at 7:32 PM · edited Fri, 06 April 2007 at 7:33 PM
there are two ways to do what Miss Nancy said, one is to parent from the parameter dials (doesn't always let you) or parent from the "figure" drop down menu at the top of poser window, select "set figure parent" from the "figure" drop-down menu (that one usually works)
Be sure to of selected the gun ( should be highlighted with red line) prior to trying to parent it, then highlight / select left or right hand (whichever you want) to parent it to that hand, you may need to adjust the gun position to get it in the hand properly.
got a bit confused when you said "harness" so i'll mention this too, if you have a cop-type holster (shoulder straped) then that would need to be parented to the chest, but if you have a gunslinger-type holster (belt type) then that would need to be parented to the hip.
Hope it helps ya.
imagynart ( ) posted Sat, 07 April 2007 at 7:49 AM
Thank you, Miss Nancy and Vince3. I'll try that.
johnfields ( ) posted Sat, 07 April 2007 at 8:50 AM
I have some hand poses for guns in the hand folder - some people include them in their sets so you can more easily pose the weapons - there is also this site-schlabber.org/ that has literally thousands of poses
tainted_heart ( ) posted Sat, 07 April 2007 at 10:36 AM
You can also parent an item by opening up the Heirarchy Editor, locate the gun in the list and drag and drop it onto the hand you want to parent it to in the list in the editor.
It's all fun and games...
Until the flying monkeys attack!!!
byAnton ( ) posted Sat, 07 April 2007 at 5:05 PM · edited Sat, 07 April 2007 at 5:07 PM
To make the gun into a conforming figure you could replace the hand of a clothing cr2 with the prop.
  1. Load the figure and pose them holding a gun.
  2. Load the gun and align it to the hand pose.
  3. Save the figure posee to the libarary
then..
  1. Delete the figure.
  2. Load any clothing item cr2 for the figure that has some visible hand group geometry.
  3. Apply the saved pose to the clothing
  4. Select the hand group and click "Replace Part with prop" and Select the gun.
  5. Turn of "Bend" under properties.
  6. Turn all other parts except the gun invisible
Save this new figure to the library.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
imagynart ( ) posted Sun, 08 April 2007 at 11:31 AM
Thank you all. I will take it into consideration and experimentation. :D
