Mon, Jan 20, 11:20 AM CST
Forum Moderators: Staff
Subject: Having problem getting TDMT morph swap script to work
fls13 ( ) posted Thu, 12 April 2007 at 1:39 PM · edited Sun, 05 January 2025 at 6:44 AM
The docs seem unclear to me on where exactly to path the various files. I'm using Poser 6.
Cage ( ) posted Fri, 13 April 2007 at 1:12 AM
Here's the folder path on my system.
C:Program FilesCurious LabsPoser 5RuntimePythonTDMTTDMT_script
The folders and the files they contain should be placed within your Poser Runtime folder to mimic their placement in the zip file.  Specifically, a folder named "TDMT" needs to be placed in the "Python" folder inside "Runtime".  The script will look for this folder and read and write files from/to the folder while running.  The script folder named "TDMT_script" needs to be placed inside the new "TDMT" folder inside RuntimePython.
fls13 ( ) posted Fri, 13 April 2007 at 12:02 PM
Got it now thanks. I think we're rolling. What I'm looking to do is cull excessive geometry out of the eyelash, ear and inner mouth region and bring down the number of vertices about 50%. Most of the head geometry that the existing morphs cover will remain intact. I have tested it and it does work. Hopefully your script will precisely what I'd like it to do. :O).
Cage ( ) posted Fri, 13 April 2007 at 2:26 PM · edited Fri, 13 April 2007 at 2:28 PM
"Hopefully your script will precisely what I'd like it to do. :O)."
Your use of the script is really the only one so far for which the process seems to be both fairly easy and 100% successful in tests.  JoePublic has used the script (and earlier versions of the same script) to do exactly what you seem to be doing.  I hope it works well for you.
And the script would not have gone anywhere without the help of Spanki, svdl, and others -something I just try to point out in every thread about the script....  :-P
