Thu, Nov 14, 10:45 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 9:14 am)
Subject: wireframe material
tinman_prime ( ) posted Fri, 27 April 2007 at 4:04 PM · edited Thu, 14 November 2024 at 10:37 AM
Hi,
Does anyone know how I can make a wireframe material in poser 5?
I would like to animate a wireframe charecter.
thanks
Miss Nancy ( ) posted Fri, 27 April 2007 at 4:12 PM
animate the character in wireframe display mode. render as series of images in display mode.
tinman_prime ( ) posted Fri, 27 April 2007 at 4:31 PM
I'm unable to get it to render in anyhing but full color mode. I can get wireframe in the display window only, but not in a render
Angelouscuitry ( ) posted Fri, 27 April 2007 at 5:15 PM
Select the Figure and make sure the Display > Figure Style > is Wireframe.
When you open your Render Setings, there is a tab named Movie Settings, then a DropDown named Renderer.  Select Preview from the Renderer, and render a Move(Even if it is only one frame.
tinman_prime ( ) posted Fri, 27 April 2007 at 6:51 PM
I'm using version 5 and when I goto render settings, there is no option or tab for movie settings
Angelouscuitry ( ) posted Fri, 27 April 2007 at 6:59 PM
Hmm...How many frames are there?  You could make sure the DIsplay setting is correct, and then just export the the Preview image, for each frame.
tinman_prime ( ) posted Fri, 27 April 2007 at 10:49 PM
Sory for taking so long to get back.
I looking at about 200 frames
Angelouscuitry ( ) posted Fri, 27 April 2007 at 10:57 PM
Else I'd say you could just Play the animation, and then use a screen capture utility(LIke SnagIt) to make the movie, but I doubt there is any hardware with enough resources to really get a smooth playback?
I bet this would be doable with Python, but where it is readily available in P6/P7, you may have some convincing to do in order to get a Guru's help.
