OKay here is what is going on ... I got 6 and I got 6.1 ... now the new install made my 6 into 6.1 but with no contents at all..... none.. blank....
So, now I got two separate programs.. the old updated 6.1 with my contents and my new install 6 that says it is 6.1 at the start of the program and no contents.... BTW,, the numbers 6.1.13.1 appears no where... I tried to install over my 6.1 and it wont...
History:
In the pass I had deleted my old 5, 5.5 but kept the content which went to 6 then I updated last month to 6.1.. had little contents in it.. But I imported more content from my older versions stuff...
can you help....
You should always make a backup copy of your presets just in case....
*You should always make a backup copy of your presets just in case....
*I did not lose any content.. the install did not see the content,,, Yes.. I have been saving my content.. thanks...
When you install the update, make sure you change the default pathname the installer shows to the one where your Bryce 6.1 is installed.
Once 6.1 is installed, you should not have a separate copy of B6 installed on your machine. They don't play well together.
To see the version installed, you should see Bryce 6.1 in the header bar at the top of the program and when you press Cmd/Ctrl and choose Help > About from the Menu Bar, the popup will show version 6.1.13.1.
The installer wouldd not accept to install into my existing 6.1. so I delete and kept the last update and not the new 6.1.13.1... I think I might have to delete all and start with just 6.0... then install the 6.1.13.1 on top of it...
hmm wonder if this update fixes the difuse default color prob im having with obj files (my obj import black.)
Also still pestered by the i/o bad file flyout when importing 3ds with assigned textures/maps
i repote this too the daz bug forum it was supposedly fixed but not for me.
Plus click help>about flyout says bryce 6.0 on my 6.1 upgrade
A3DLover - black .OBJ import, not fixed. Mac and PC. According to the posts at the DAZ Bryce Forum this is a conflict between the .OBJ importer and D|S animation when the .MTL file does not reference any image files. I'm glad I kept 6.0 since that imports correctly. 5.5C also works. Both versions save correctly and can be loaded into 6.1. I still can't load any .3ds files on my Intel Mac. D@M - PC right? as far as I can tell just is the exporting of terrain grayscale images is fixed.
Attached Link: Bryce 6.1.13.1 post
The 6.1.13.1 update is out, Mac and PC. It's found by reseting your Bryce 6.0 in the Order History. The only thing that's changed is the app itself. Downloading now so I'm not sure of all the changes but the post below lists the following: Mac Tree Lab fixes where default tree could not be modified at all PNG image export from Terrain Editor now exports as PNG instead of MOV 6.0 changed to 6.1 in header bar and Help > About Best; Dan
