Wed, Dec 25, 11:57 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: first test using vue shaders
prode ( ) posted Mon, 30 April 2007 at 4:07 AM · edited Wed, 25 December 2024 at 12:26 AM
hi all, just wanna show you my first test with some imported Vue mats (via PLE version) in the "house interiors" scene; the synergy between vue material presets and carrara speed render engine looks promising
Sethren ( ) posted Wed, 02 May 2007 at 3:02 AM
I don't get it. How did you import Vue Materials?
I thought Carrara did not read Vue Material files or am i missing something here?
prode ( ) posted Thu, 03 May 2007 at 3:02 AM
actually all I do to speed up import/export transfer is create an alpha plane or a terrain in Vue PLE (or Infinite or Xstream if you own them), assign a material, select  and export it as .3ds object  paying attention to check color and bump maps and map resolution at 400x400 and then simply import into Carrara; in the linked image walls painting, wood floor, wood side tables and sofa texture were made this way; obviously with Carrara you can reach same results but in Vue there are many excellent prompt shaders so why not to be useful of?
ggrace ( ) posted Wed, 09 May 2007 at 7:22 PM
Many Thank you's for this tip!  Some of my favorite shaders are in Vue.
Glenn
