Fri, Feb 14, 12:32 AM CST
Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Subject: Something Completely Different.......
mjshepherd ( ) posted Wed, 16 May 2001 at 5:37 PM · edited Tue, 26 November 2024 at 11:23 PM
Normally I don't touch anything religious, just in case I cause offence. I appreciate my taste isn't the same as other peoples when including religious items in images! However, I did need a cross for an image I'm working on, and got playing about with this one after deleting the graveyard from the background........I quite like the result, and it taught me a little bit more too!
bsteph2069 ( ) posted Thu, 17 May 2001 at 1:47 AM
I agree. Photoshop can be a real witch to use. In fact I frequently don't use it because it's easier in PSP since I am better aquainted with it. Of course I think Photoshop ultimately is better. Usually what I can currently do in photoshop I can do in PSP. Except there are no paths function. Using the lasso on a picture larger than my screen size is a real pain. Bsteph
mjshepherd ( ) posted Thu, 17 May 2001 at 5:18 AM
There y'go, Alpha! Resized down to save load time. Cross taken with the usual MX1200 from a low viewpoint. Not much work to the cross itself, just a sanstone texture. Variated blue background added, lens flare thrown in, drop shadow upover on the cross itself, background texture and a single lighting effect. Voila! p.s. Thanks again for the comment - for the first time since I started playing with cars I've found something I really feel at home with. Apart from Grand Theft Auto, of course, but that goes without saying! :-D
mjshepherd ( ) posted Fri, 18 May 2001 at 5:25 AM
Aplha, top notch! Erm - you moved the cross too? did you cut that out and rotate it slightly? Cool pic. Never even thought of anything like this! Howwwwllll!
mjshepherd ( ) posted Sat, 19 May 2001 at 5:37 PM
Our lass does that, I think it's called PMT..... (Ouch!)
