Mon, Dec 2, 1:19 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:09 am)
Subject: script to reverse pose of a character
dennisharoldsen ( ) posted Tue, 15 May 2007 at 2:34 PM · edited Sat, 30 November 2024 at 6:56 PM
thanks for the previous crucial help from nruddock and PhilC.
it would be nice to have a script to reverse the pose of a character.
i got the idea from the folowing script.
this is a script i downloaded.
sometimes it works but the result is not always what i expect.
i can send images to show this.
Swaptotal.py
Flip the symmetry of the whole figure with one button push.
Copyright (c) 2005 David G. Drumright (ockham)
import poser
scene = poser.Scene()
In currently selected figure, swap right and left.
try:
  TheFigure = scene.CurrentFigure()
except:
  exit
scene.SetFrame(0)
TheFigure.SwapTop()
TheFigure.SwapBottom()
MidlineList = ["BODY","Neck","Upper Neck","Head","Chest","Abdomen","Hip","Left Eye","Right Eye"]
for Name in MidlineList:
    try:
        OneActor = TheFigure.Actor(Name)
    except:
        pass
    try:
        TwistParm = OneActor.ParameterByCode(poser.kParmCodeYROT)
        TwistParm.SetValue(-TwistParm.Value())
    except:
        pass
    try:
        SideParm = OneActor.ParameterByCode(poser.kParmCodeZROT)
        SideParm.SetValue(-SideParm.Value())
    except:
        pass
PhilC ( ) posted Tue, 15 May 2007 at 2:51 PM
Rotoscoper has that and a number of other posing options.
svdl ( ) posted Tue, 15 May 2007 at 3:07 PM · edited Tue, 15 May 2007 at 3:08 PM
file_377652.doc
I can understand why it doesn't always work: the MidlineList is not valid for all figures (this one is valid for Victoria 2 and Michael 2, and will probably work on Posette, Dork and the Millenium 3 figures). It also won't work on non-English versions of Poser.
I've rewritten the script to swap all figures, independent of Poser language and body part names. See attached file. Save as SwapFigure.py.
My gallery   My freestuff
dennisharoldsen ( ) posted Tue, 15 May 2007 at 4:43 PM
PhilC
thank you.
i have done lots of research to understand poserpython.
you are one of the few who does.
Rotoscoper  sounds very capable and i going to check it out.
i am looking at learning more about poserpython.
it is dramatically under-doucumented.
is the python code in Rotoscoper visible?
maybe we can talk.
dennisharoldsen ( ) posted Tue, 15 May 2007 at 4:50 PM
svdl
thank you.
your code is quicker and more reliable.
however, the result is still varied.
i am sending my test results as a jpg.
it shows an initial pose that is changed and changed again.
i am trying to understand poserpython but it is a challenge.
you know that better than i do.
jonnybode ( ) posted Fri, 18 May 2007 at 12:51 PM
Hi Dennis!
Excuse me if this is a silly question, when I swap a pose i go to "Figure/Symmetry/Swap right and left", I guess you are after something more?
Im just curoius what the result of your script shall be?
Regards / Jonny
jonnybode ( ) posted Sat, 30 June 2007 at 3:48 AM
