Tue, Nov 26, 3:33 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: P7 Rendered Texts get fuzzy
Huolong ( ) posted Fri, 18 May 2007 at 1:26 PM · edited Tue, 26 November 2024 at 3:31 AM
I like to make my own textures from my Poser scenes and paste them to flap panels as signs, windows, etc.   As of late, Poser 7 makes the rendered scenes often so fuzzy as to be useles.
Gordon
Miss Nancy ( ) posted Fri, 18 May 2007 at 6:01 PM
texture filtering on? post filter size > 1? final vs. draft settings?
Huolong ( ) posted Sun, 20 May 2007 at 1:38 AM
The image in the center is what is saved in a render and is clear, but the image on the left is applied to a surface unrendered and the right rendered.   Something happens when the image is used as a texture and re-rendered as opposed to the same picture not applied as a texture.
Gordon
semidieu ( ) posted Wed, 23 May 2007 at 3:41 PM
What are your render settings (screenshot) ?
Huolong ( ) posted Wed, 23 May 2007 at 5:15 PM
It's the setting in the Materials Room for the particular texture which in P6 is a general setting ... presumably this cuts down on the overall speed of rendering.
Gordon
Miss Nancy ( ) posted Wed, 23 May 2007 at 6:08 PM
turn off texture filtering. make sure post filter size = 1 (default). use final (not draft) render settings.
semidieu ( ) posted Thu, 24 May 2007 at 4:13 AM
Can you show us the general render settings (ctrl+y) ?
Huolong ( ) posted Thu, 24 May 2007 at 8:39 AM
It's the specific setting that affects the fuzziness of a particular texture.
Gordon
Huolong ( ) posted Thu, 24 May 2007 at 8:41 AM
These are the settings I use most often
Gordon
semidieu ( ) posted Thu, 24 May 2007 at 1:53 PM
Set "min shading rate" to 0.20. It should solve the problem.
