Tue, Nov 26, 5:25 AM CST
Subject: Output render different than screen render
jackhalsey ( ) posted Mon, 21 May 2007 at 10:16 PM · edited Tue, 26 November 2024 at 2:45 AM
Hello
I am doing a render of some png files.  I have tried changing the background to black and also checking render over black in the render options.
So then I go to make movie and check image files and export 3 test renders.
I watch the renders in poser and all of them have a black background but when I go and open the output folder containing the pngs they have a white blackground.
Please advise.
silverthornne ( ) posted Mon, 21 May 2007 at 10:23 PM
PNG's actually have a transparent background so you can put them on top of anything else easily in an image app such as Photoshop or Paint Shop Pro. If you want the black background you should go for another format.
jackhalsey ( ) posted Mon, 21 May 2007 at 10:58 PM
Thank you but now when I go into make movie the options button next to format is greyed out and I cannot choose which type of image file or avi to export.  Please advise.
linkdink ( ) posted Mon, 21 May 2007 at 11:25 PM
I think you can take those pngs and just convert them to jpgs or bmps or some other format and your background will change from transparent (the white you see) to a solid color. I think.
Gallery
silverthornne ( ) posted Mon, 21 May 2007 at 11:35 PM
You don't get to choose that until you click the "Make Movie" button. I know it's counterintuitive, but once you use Poser for a while you get used to it's weird quirks.
gagnonrich ( ) posted Mon, 21 May 2007 at 11:43 PM
You can always use the rectangle propr, from the Primitives folder and color that black and resize it to fill the background.
My visual indexes of Poser content are at http://www.sharecg.com/pf/rgagnon
jackhalsey ( ) posted Tue, 22 May 2007 at 12:43 AM
Thank you all you solved my problem.
