Sat, Dec 28, 3:46 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: How do you Cut through clothing to reveal skin beneath???
kathym ( ) posted Wed, 23 May 2007 at 4:27 PM · edited Fri, 27 December 2024 at 12:03 PM
I'm trying to slice through the Artemis suit in order to reveal cuts beneath ( like you would find if your belly was slashed at through your shirt) - I thought it would be as simple as placing the suit texture over a transparent background in photoshop - but that didn't work. Any ideas on how to achieve this?
Just enjoying the Vue. :0)
BAR-CODE ( ) posted Wed, 23 May 2007 at 4:32 PM
You can make a transmap for it ..
take the texturemap of the cloth you want to slice ..
and put a layer ontop of it ..
Make the scar/slice fx on the right place.
And use the layer as a transparent map..
in poser lay the transmap over the cloth texture and you have a cut ..
I think others can explain it much better but this is the only way i know how to do it ...
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
ian_colette ( ) posted Wed, 23 May 2007 at 6:06 PM
Pretty good explanation, but the other thing you need to do (very important) is make the slash part black & everything else white.  In a transparency map Poser sees white as opaque, black as transparent, & shades of grey as semi-transparent (the darker the grey, the closer to transparent the result, great for making sheer parts in clothes).
Acadia ( ) posted Wed, 23 May 2007 at 6:28 PM
Attached Link: http://www.philc.net/Scissors_page1.htm
PhilC has a great tool called "Scissors"
Tashar59 ( ) posted Wed, 23 May 2007 at 9:58 PM
Any one of the free modeling apps. But the trans map way would be the simplest. No real need to spend money for one time use as this.
thefixer ( ) posted Thu, 24 May 2007 at 2:44 AM
Online Now!
kathym: I have a tute on my site that gives step by step instructions on how to do this with transmaps.
You will need Photoshop or another 2D app as well.
The tute is also located on Ravynsworld's web site!
Injustice will be avenged.
Cofiwch Dryweryn.
thefixer ( ) posted Thu, 24 May 2007 at 2:46 AM
Online Now!
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1396235
This book cover [in print] has the Cossack outfit by Renapd on it with the rips and tears done with transmaps from my tute and using Ravynsworlds brushes for Photoshop!
Cofiwch Dryweryn.
