Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
The main area used to cover the viewing area. Now I have these strips of nothing on either side and it's driving me crazy as my pic extends on either side but those areas don't render. I'm thinking I must have chosen something in the options to do this. Is there any way other than re-installing the program to reset it?
Thanks,
Marque
This is due to the aspect ratio you chose (maybe without meaning to) for the image. It's normally set to standard PC 4:3 which fits, as the name implies, on the screen (assuming you don't have some odd monitor size). If I choose standard PC vertical 3:4 I get the same bars as you. Vue is showing you the non-renderable areas due to the chosen aspect ratio.
Just set it back to standard in the render settings and it'll be OK.
Steve
It would be interesting to know if Marque has just changed his display, because if not (and if it all looked okay beforehand on the same monitor) I stil think that the image aspect ratio must have changed. According to my quick calcs the screenshot is 1360 x 768 - which is a perfectly respectable monitor size, but well off the 4:3 ratio, so yes, it could be the display size causing this.
Have to say though that my monitor is not 4:3 (it's 1280 x 1024, which is 5:4) and I don't get those strips with an image of 4:3 aspect ratio.
Steve
It seems to be clipped on either side, never had this happen before. Is it because I set it to run like Maya? And if so how do I get it back?
Thanks,
Marque
