Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:45 pm)
This sounds like a memory problem - consider upgrading your RAM to at least 2Gb. Your graphics card won't make any difference, btw.
Have a look at GlowWorm (http://www.poseworks.com/glowworm/), which lets you batch render and, for your current situation, divide a scene into sections. These are rendered individually and you stick 'em together in Photoshop (or whatever). I've found this really very useful.
Also, there's a Python script floating about somewhere, I think it's a freebie, which will render each figure in a scene individually - maybe someone reading this can help track it down.
PoserPro 11 - Units: Metres
Adobe CC 2017
This is what I do when my renders start to choke:
--Make sure all background tasks are killed unless they're necessary (learned that trick from playing The Sims LOL!)
--Don't have any messengers open.
--Try not to open any webpages to keep from lagging up your machine.
--Save the poser file and restart the program to give it a fresh start before rendering.
These things usually help get my renders movin' and hopefully they do the same for you. I haven't the slightest idea what specs my laptop has but if I can render a 1275x800 image with two figures (close-up) and several props in about 5 hours on it, then it must be pretty good LOL!
Before I do this Anasta, I restart my PC. (Not RESTART but turn OFF and restart).
Reducing bucket size down to 8 sometimes kicks things off.
Some say to remove ( or make not visable) anything you don't need to see in your scene (though I question this)
Some say that minimising the Poser window at the start of the render process frees up memory.
Personally, I'd turn off my puter and restart, open Poser, open the pz3 and try rendering with no other windows open. But you've probably already tried this.
I'm working on a piece for a competition. The scene has several figures and a large prop, and a large scene/bg. Everytime I render I just get this message.
"There was a problem during render.
when using firefly you can reduce memory usage by rendering in a separate process, raising the adaption threshold or specifying smaller bucket size."
No matter what I do I cant seem to get the render sorted.
The image must be 1024x768.
Has anyone else encountered this....how can I fix the problem. I have a 64 bit machine, ATI Radeon 7000 card. 1GB ram.
Thanks for listening
