take a look in the batch folder - there's probably a job sat in there
My Freebies
Buy stuff on RedBubble
Hello.
Thanks for your reply. There was a job sitting in there, and clearing it out has stopped the Standalone mode from kicking in automatically.
However, Vue is still starting to render images without my consent. As soon as I hit the EDIT button to load my nodes, it shuts down the window and starts to render my image. No jobs where scheduled.
If I abort, it will somehow place 4 projects to be rendered into the schedule all on it's own (same project 4 times).
Do you think at this stage it's just better to reinstall the software ?. I has behaved up until tonight.
Kind Regards.
James.
it's been a while since I used hyperview 'cos it kept crashing on my install - try aborting the job then deleting it from the hyperview manager. That might do the trick
My Freebies
Hello.
I tried to do what you suggested, but Vue would not allow me. The second I abort something, it creates 4 more. Tring to unload the nodes didn't help either as Vue would just rescan for them on it's own faster than I could shut them down.
Anyway... some good news. This is such strange behaviour, I decided to reinstall vue. It's working perfect again. I have an idea of what I did at this point to cause all this so I'll file a bug report with e-on.
Thanks a million for all your help.
Kind Regards.
James Tubbritt.
No, I'm using a custom setting, but I'm also turning off the dof and motion blur. The problem is if I set the resolution to anything higher than 3000 X whatever X 300 DPI, I then have to reinstall the software to clear out whatever sort of glitch this is causing. Shutting down, rebooting and clearing out any scheduled jobs does not help. Only reinstalling the software frees up the system again.
I've just verified this this morning by painfully having to reinstall 4 times in order to see if I could recreate the problem.
Regards.
James.
Hi Guys.
All of a sudden when I select the Edit option in HyperView in order to load my nodes, Vue will automatically start the standalone rendering process without my consent.
Any idea's why ?.
I've tried rebooting, and I've not changed a single setting either.
Kind Regards.
James.
