the original P4 skeletons have no textures and their UV mapping is pretty sad as well (ie dificult to work with to get a good looking skeleton) You can use UV mapper to remap them and create a new base figure. if thats too dificult, then just pose the way you want, export as an obj. and remap using uvmapper for that pose. I had to do that on more than one occasion when first starting out.
aka MCDLabs
also known as Daniel Merrill a grumpy old disabled Jarhead.
checkout my freebies at
https://www.sharecg.com/pf/full_uploads.php?pf_user_name=mcdlabs
UV mapping means you take a 3D model to pieces and lay them out flat like a tailor's pattern. You then save the model and an image of the flat pieces. You can use this image as the basis for painting a texture (in Photoshop, for example).
UVmapper is a popular program for doing this. A limited, freeware version is available.
Be aware that the early Poser models were a bit crude, and UV mapper can mess up the skeleton model - it did for me! But you can re-map the skeleton with a bit of work.
Ok, I know I am a bit of a beginner here, but I cannot find the poser 4 skeleton textures anywhere. Could one of you good people direct me to the appropriate place.
Thank you in advance.
~Wurk
