Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Quote - I would to know how i could put a clickeable link in the notes i add when uploading a picture.
I'm sure you just need to use the correct HTML e.g. Some text here
Quote - noel, it's clever how you used the character codes to display the html code without letting it be interpreted by the user's browser. I useta just type instead of the angle brackets, then tell 'em to use the angle brackets. p.s. their html editor doesn't display in any of my browsers.
Not clever unfortunately
The new editor doesn't require you to anything special to type example HTML code, it automatically translates special characters to their entity equivalents
It's only when you need to have insert "active" HTML that you have to use the Source button to stop that from happening, e.g. to add
andtags for posting properly formatted code (e.g. Python or a sample from a Poser file).
If you use HTML in your gallery upload comments, make sure you aren't using it to give credit to merchants and/or freebie creators, even if said products are available here. Apparently that's against the rules. If you want to give credit for things, you have to use the built in credit feature when you are uploading. So far as giving credit to freebie creators and merchants on other sites, and such, you can only list a name and mention the name of the site it's found, but you can't link to it.
say." - Ghandi
Ok Acadia, no probs :)
Though i never manage to understand how the built in credit feature works :s
Quote - Ok Acadia, no probs :)
I find the built in credit system to be cumbersome and tedious. I don't bother with credits anymore since that system was incorporated.
say." - Ghandi
Hi all!
I would to know how i could put a clickeable link in the notes i add when uploading a picture. I saw this several times on other people gallery, but was unable to do the same.
