Wed, Feb 12, 7:00 PM CST
Subject: Weird render issue
Starkdog ( ) posted Sun, 27 May 2007 at 6:12 PM · edited Sat, 08 February 2025 at 1:54 PM
I am using V4 with Milan textures, and softbox lighting. Everything renders great in Poser7, except for this little patch. I remember Poser6 having some issues just like this, but it was fixed way before Poser7. I turned off texture filtering due to seams showing in the renders. What setting do I need to tweak? Thanks, -Starkdog
pjz99 ( ) posted Sun, 27 May 2007 at 7:42 PM · edited Sun, 27 May 2007 at 7:43 PM
Does that happen with any lighting setup?  Does that always happen right at that particular spot, even when lights are moved around/turned off?  How does it look with 1 light?  What are shadowmap settings for your light(s)?
ps: have you actually looked at the torso texture? are you using any kind of blender setup e.g. mixing in trans mapped pubic hair or something?
My Freebies
Starkdog ( ) posted Sun, 27 May 2007 at 8:30 PM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1450008
I fixed the problem. I turned off texture filtering to negate the visible seams issue with Milan. While I was double-checking this, I noticed that the "normals forward" box was unchecked for all of the textures; I checked every one, and things rendered fine. Poser 7 is acting up on me today. I lost the scene when it crashed while saving, but at least I got the render. Link contains nudity. -Starkdog
pjz99 ( ) posted Sun, 27 May 2007 at 9:25 PM
Very well :) mental note to disable texture filtering on my own stuff, I keep meaning to do that.
My Freebies
