finished render time. The work flow for an animator in Poser is to move the slider to a frame in your animation, get the pose correct, check all render settings, then render a single frame. Then, if you want to see how the exact same frame would look with more intense settings, such as min. shade and raytrace bounces, you change the setting and render again. Then, you can use the slider to compare the two. If the final render time for each example were displayed, it would help you decide if the extra intensity is worth the render time. From what I here, yes, rendering single frame only, render time is less important, although I understand some people have complex scenes that take 14 hours to render, I guess that COULD make a difference! ::::: Opera :::::
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2195618
There is a python script which displays the render time for you. See above link.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.keindesign.de/stefan/poser/scripts/timedrender.py
Here's the render time script I'm using.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I wonder why Poser does not store the render time as you are working along and make it available? Seems an obvious feature.
I end up using pen and paper to write down times and then ACTUAL DO ARITHMETIC to calc render time. How's that for old school?
How do you all track render times?
I wish you could (optionally) have Poser time the render and display the time in hrs/min/sec on each saved render in the "saved renders slider thingie".
::::: Opera :::::
Message edited on: 11/20/2005 03:22
