Sat, Feb 8, 2:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Subject: Poser Pro templates?
skee ( ) posted Thu, 31 May 2007 at 10:30 AM · edited Sun, 04 August 2024 at 2:41 AM
I am looking for the templates for the Barney Poser pro figure, I have for the textures, but for the
life of me, I can't find the templates. If someone knows where to find them, either online or in the program, it would be great. Maybe they are not to be found.
I would like to remap this charactor.
skee
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
kuroyume0161 ( ) posted Thu, 31 May 2007 at 11:21 AM
There are no texture templates for most of the stock Poser figures by default.  If you have UV Mapper, you can load the figure geometry (Runtime:Geometries:ProPack:Barney.obj) and save a template from there.
If not, I can get you one.
When you say 'remap', do you mean just to change the colors using the template or actually change the UV mapping?  A template won't help for the latter.
Robert
 -- Bjarne Stroustrup
skee ( ) posted Thu, 31 May 2007 at 3:43 PM
Thanks for the reply. What I would like to do is change the clothing look. I would like to
make him look like he has on shorts and remove the buttons from his shirt. I would also
like to be able to change the skin tones.
I can get uv mapper and learn how to use it, in the mean time that templace would be nice,
thanks.
skee
kuroyume0161 ( ) posted Thu, 31 May 2007 at 3:50 PM
You can download it here:
http://www.kuroyumes-developmentzone.com/private/Barney_template.bmp
This is a 1024x1024 BMP template in RGB (about 3MB).  I've used UV Mapper to color code the material zones.  Load this into PhotoShop or PSP and use as a background layer for your texture changes.   You can load the default texture from "Runtime:textures:ProPack:BarneyM.jpg" if a reference is needed.
Robert
skee ( ) posted Fri, 01 June 2007 at 2:29 PM
Thanks Robert.
Sorry it took me so long to get back to you. You are very generous to do this.
skee
