Mon, Feb 10, 7:23 AM CST
Subject: Poser 7> adding body movements to a walk path
mhscspo ( ) posted Thu, 07 June 2007 at 9:00 PM · edited Thu, 06 February 2025 at 11:41 PM
I saw a tutorial on the e-frointier web site on how to add bod movement to a wlk path for Poser 6, I tried to do the same in Poser 7 but it doesn't work at all, how do you add head and arm movements in Poser 7 after you have created a walk path?
sdraun ( ) posted Thu, 07 June 2007 at 10:04 PM
Quote - I  how do you add head and arm movements in Poser 7 after you have created a walk path?
Widow>Walk Designer  -------is the standard way. Post again if that doesn't work
Steve
mhscspo ( ) posted Thu, 07 June 2007 at 11:12 PM
I've done this already, in the walk designer there is no way to change the direction of the head or make the hand wave. This is supposed to be  key frameable at different times on the timeline after creating a walk path and using the walk designer
jdcooke ( ) posted Fri, 08 June 2007 at 10:37 AM · edited Fri, 08 June 2007 at 10:43 AM
Hey mon, With Poser 7 we now have animation layers. After you make a walk animation open up the animation palette and then select the "layers" tab. You should see a new "walk animation" layer. Select THAT layer and then you can begin effecting the walk animation. You can also create a new layer to add animation over top of the base walk layer. It can be confusing at first, but non-linear animation layers is a very powerful feature. take care jdc
mhscspo ( ) posted Fri, 08 June 2007 at 11:47 PM
Thank you so much jdcooke, I was pulling my hair out over this one!
