Hey mon, With Poser 7 we now have animation layers. After you make a walk animation open up the animation palette and then select the "layers" tab. You should see a new "walk animation" layer. Select THAT layer and then you can begin effecting the walk animation. You can also create a new layer to add animation over top of the base walk layer. It can be confusing at first, but non-linear animation layers is a very powerful feature. take care jdc
I saw a tutorial on the e-frointier web site on how to add bod movement to a wlk path for Poser 6, I tried to do the same in Poser 7 but it doesn't work at all, how do you add head and arm movements in Poser 7 after you have created a walk path?
