Good catch Wabe (as usual :o)
I think 5x to 10x is typical and also when you import 3D models.
And another newbie tip: If you can't get lights bright enough with the slider, type in larger values. You can type in much larger that the max slider values in most Vue sliders. I often have light intensities of 1,000 to 5,000.
Hi All. I searched for this but I can't seem to find an answer and I refuse to believe I am the only one having this problem.
In Vue 6 xStream when I create a normal spotlight the wire frame for that spotlight is huge. And I can not find a way to shrink it or hide it. Is there a way to make the wire frame for the spotlight (not the light eminating from it, but the spotlight itself) in order to make it a more managable size?
Thanks,
John
