Sun, Jan 26, 5:38 PM CST
Subject: Props library not popping up no more
sirenia ( ) posted Sun, 17 June 2007 at 5:53 AM · edited Sun, 26 January 2025 at 5:30 PM
Hi all, I recently have this problem with my Props Library not showing up (read: popping up) anymore in the Poser Library Window. I have no clue why whatsoever because the Props folder is 'only' about 390 MB and the Charakter folder (for example) is about 2,31 GB and this one works just fine popping up in the Library as well as all the other ones do. I have Poser 6 sr 3 on Mac OS X 10.4.9 Can anybody help me solve this please ? Thanks Wim
Society failed to tolerate me...
... and i have failed to tolerate society
nghayward ( ) posted Sun, 17 June 2007 at 8:49 AM · edited Sun, 17 June 2007 at 8:50 AM
Have you ckecked to see if the Props folder has been renamed/moved/deleted?
Poser 6RuntimelibrariesProps
sirenia ( ) posted Sun, 17 June 2007 at 10:41 AM
Yes, it's still there. Did not removed or deleted or renamed it.
geep ( ) posted Sun, 17 June 2007 at 12:10 PM
Um ......... Have you tried resetting Poser to the "Factory" state? :blink:
Just a thought. :huh:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
sirenia ( ) posted Sun, 17 June 2007 at 12:52 PM
Just tried it... but did nothing :sad: The wierd thing is when i load a figure in the main window, the Props tab shows all the parts from that figure, and then when i select a part (via the library Props tab) it actually opens a prop folder in the library :blink: For some reason the Props library is misreading somehowe what it is supposed to read i think.
geep ( ) posted Sun, 17 June 2007 at 12:56 PM · edited Sun, 17 June 2007 at 12:57 PM
Uh oh ....... it may be time to (re)install Poser. :scared:
no cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
sirenia ( ) posted Mon, 18 June 2007 at 12:03 PM
Aaaaah !!! :scared: Why is that ? Do i have to re-install everything i ever put in the runtimes again ? And probably also update the service releases again ? Where do i find them these days, now that almost everything is for Poser 7 ? Sorry for the many questions :blushing: Wim
geep ( ) posted Mon, 18 June 2007 at 12:30 PM · edited Mon, 18 June 2007 at 12:34 PM
You should NOT need to reinstall everything ... just Poser + the SR(s).
It's (always) a good idea to backup your "Runtime" directory before you reinstall Poser just to be safe.
cheers,
dr geep
P.S. If you do not have copies of the SR(s), contact e-frontier to request them.
You will probably need to provide your s/n for Poser.
cheers,
dr geep ... :o]
edited 10/5/2019
sirenia ( ) posted Mon, 18 June 2007 at 12:46 PM
Thanks, I will try re-installing somewhere next weekend and ask e-frontier the s/r's links. Wim 😄
nghayward ( ) posted Mon, 18 June 2007 at 2:17 PM
Before reinstalling try deleting the LibraryPrefs.xml file in the runtim: prefs folder. I'm not saying it will definately work but it will save on a full reinstall if it does. The only problem would be you'd have to add any external libraries back.
If you need them the SR is available from the http://www.e-frontier.com/go/downloads/updates
sirenia ( ) posted Tue, 19 June 2007 at 12:53 PM
Just tried it, but nothing... Thanks for the link !
sirenia ( ) posted Sat, 07 July 2007 at 4:38 PM
Well, i did the re-install from the original disc and the sr updates again but... still no solution :crying: Anything else someone can think of ? It has to be a bad file somewher no :blink: ?? Wim
Acadia ( ) posted Sat, 07 July 2007 at 5:46 PM
Move your runtime out of your folder and any other files you want to keep IE: Python stuff.
Uninstall Poser.  Reboot. Install Poser and the SR updates. Reboot.
sirenia ( ) posted Sun, 08 July 2007 at 4:40 AM
Just tried something else: When i navigate to the most upper level in the library tab (there where you can see the folder 'Poser 6' with a big red dot next to it) and from there on i navigate back to the subfolders, suddenly it works again !! However, once i select a prop, it loads fine but after that i lost the 'Props' menu again 😕
Acadia ( ) posted Sun, 08 July 2007 at 6:01 AM · edited Sun, 08 July 2007 at 6:01 AM
Maybe it has something to do with the way you have poser set to display.  Right click in the scene area and look if you have Open GL or that Skree or whatever.  Try both. Pick which one works best for you.
TrekkieGrrrl ( ) posted Sun, 08 July 2007 at 2:45 PM
Have you checked if you've installed anything with weird characters in the filename lately? That CAN cause all sorts of problems with the folders.
I've never heard of a whole palette refusing to show up, but...
I would check - double - and triplecheck the names of the props folder. Since that is the only one you're having problems with, the problem must be in there somewhere.
sirenia ( ) posted Mon, 09 July 2007 at 12:13 PM
Thanks for the help you all :blushing: Acadia i tried Open GL and Skree like you said, but it makes no different. TrekkieGrrrl i'm gonna check again like you say, because indeed that's the only one that gives me problems. Is it possible that there are 'hidden' files in that folder with weird characters for a name maybe?
