Thu, Jan 30, 2:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: I swear I wont ask again...but:
jjroland ( ) posted Thu, 21 June 2007 at 11:14 AM · edited Tue, 28 January 2025 at 11:57 PM
I know this has been covered before but I can not recall the solution.  My render is coming through with the little white line/dashes all through it.  What is the fix again please?
I am:  aka Velocity3d
kalon ( ) posted Thu, 21 June 2007 at 2:14 PM
You might want to post a picture... I'm confused about the little white line fix and the little black dot fix. 😄
kalonart.com
jjroland ( ) posted Thu, 21 June 2007 at 4:19 PM
Bah Im sorry I should have posted back sooner - I got caught up in one of my ten million current projects lol.
Anyway sorry no picture now - I managed to fix it before I moved on.  It's the problem you get when using props and whatnot for poser5 and earlier I think.  The solution is apparently to add a displacement blender node.  At least thats what I did and all the little white lines are gone = D
Thanks for reading my ? anyway
Morgano ( ) posted Thu, 21 June 2007 at 4:53 PM
It sounds like the problem you can get in Firefly with Minimum displacement bounds set to zero.   I always put it at 0.2.   If it is that, then the problem would be with Poser 5 stuff and higher, rather than Poser 5 and lower.   I am not sure that I have seen the problem at P7, but that's probably because I change Minimum displacement bounds automatically.   I don't thing anything has actually changed in the Firefly engine that would cause the effect to disappear.
