Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
You might want to post a picture... I'm confused about the little white line fix and the little black dot fix.
Bah Im sorry I should have posted back sooner - I got caught up in one of my ten million current projects lol.
Anyway sorry no picture now - I managed to fix it before I moved on. It's the problem you get when using props and whatnot for poser5 and earlier I think. The solution is apparently to add a displacement blender node. At least thats what I did and all the little white lines are gone = D
Thanks for reading my ? anyway
I am: aka Velocity3d
It sounds like the problem you can get in Firefly with Minimum displacement bounds set to zero. I always put it at 0.2. If it is that, then the problem would be with Poser 5 stuff and higher, rather than Poser 5 and lower. I am not sure that I have seen the problem at P7, but that's probably because I change Minimum displacement bounds automatically. I don't thing anything has actually changed in the Firefly engine that would cause the effect to disappear.
I know this has been covered before but I can not recall the solution. My render is coming through with the little white line/dashes all through it. What is the fix again please?
