Mon, Feb 3, 8:48 PM CST
Subject: Can someone Help me with Ui Dots
andrewe_665 ( ) posted Sat, 23 June 2007 at 3:49 PM · edited Mon, 03 February 2025 at 8:34 PM
 Explain how to use UI dots
Thanks
Gareee ( ) posted Sat, 23 June 2007 at 4:33 PM
Look on page 27 of the manual.
Read the instructions.
Then just use them.. ;)
geep ( ) posted Sat, 23 June 2007 at 5:07 PM
Attached Link: Lot's of FREE Poser utorials here
(click for a full size image)
Hi andrewe_665,
Here's an excerpt that may help ... there's plenty more  tuts where this cam from over at Dr Geep Studios ... all FREE.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ashley9803 ( ) posted Sat, 23 June 2007 at 9:20 PM
While we're on the topic, my dots dissapeared on my pose screen when I got a widescreen monitor. Not behind the preview window, not anywhere.
When I go to the material room I can see them and move them around, but back in the Pose screen they're nowhere to be seen.
geep ( ) posted Sat, 23 June 2007 at 10:04 PM
You might try resetting Poser back to the "Factory" State.
Here's how to do it.
[menu] "Edit" >>> "General Preferences..." >>> "Document" >>> "Launch to factory state"
... also ...
[menu] "Edit" >>> "General Preferences..." >>> "Interface" >>> "Launch to factory state"
If this does not work, try increasing your screen size and then restarting Poser.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ashley9803 ( ) posted Sat, 23 June 2007 at 10:32 PM
Thank you doctor.
equan ( ) posted Sat, 23 June 2007 at 10:42 PM
The UI dots are memory dots so that if you change the way the programs looks as far as size of document, whether the library is open and to what folder, or if params/properties are open. Say you change the size of the document window and you want to remember the size, you resize the window, and then click on a memory dot to save the new size to memory. To clear the dot, just hold down the ALT button and click on the dot to clear it. Hope this helps. you also have Camera dots and Pose dots
