1- Don't know what it is. What kind of file was it?
To remove a dot, (ALT_Rightclick)
There are alsoPose and Camera dots, handy for saving Poses when working on clothroom, animations and so on. Same for the cameras.
Sending a pzz file to another person generally won't do much good unless you have included everything needed for the scene or the recipient has all of the elements used in the scene. I think P6 has an uncompress script, if so, try it to uncompress your pzz file. Turn off Poser's compresion and see if it will load.
Attached Link: Dr.Geep Poser tutorials.
Try what nickshield suggested.As for the dots, you are saving on a gray dot right? If it is color it is a set dot.
Try Dr.Geeps tutorials. He has one for the uI dots, I think it is in the P4 tutorials. If not look around the rest of the lesson.
the file attached. I created this saved it. When I went to reload, it would not appear. So can any body see if they can load it.(poser 6)
Explain how to use UI dots
Thanks
