Forum Moderators: RedPhantom
Quote - Sounds like your camera is in a wall, often happens with this type of scene. Looks ok on preview but render it and you just get black!Try moving your camera in a few steps and see if that works!
Agreed. I do lots of architectural render, and this sort of things happens quite often. And not just in Poser
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
Thanks guys for the quick responses. I feel like a right plonker now.
I updated my card drivers just in case however it was a camera issue which I never really thought about before :(
If I go with the main camera without any adjustments it doesn't seem to matter how I position the scene, all I get is a render of what must be a wall .
Switching to the dolly cam, for example, works a treat.
I'll play around some more. Thanks again.
Sounds likely to me that you have the scene lit with one or more Infinite lights, with shadows turned on - so the walls block your lights as seattletim suggests. Pick a light, and disable shadows in Parameter Dials -> Properties for that light, and try a render. If you suddenly get light in the scene, that's the problem.
I purchased an interior set yesterday from Renderosity which states Poser 5/6 minimum required.
I can use individual props from the set and they render correctly however if I load the base structure - the walls, floors etc , then as soon as I try a render all I get is a blank screen - this might be black, brown...whatever.
I've tried turning on/off render options in firefly and the poser 4 render engine but doesn't make any difference apart from I get a blank screen rendered much quicker or slower than before!
I can do a sketch render and a preview render no problem ?
Everything else I've downloaded / purchased seems to be working fine .
I've dabbled with increasing bucket sizes, running a render as a separate process, etc but to no avail.
I've got 2gb of ram and running an Nvidia 5700 graphics card. I've updated Poser to SR2 .
Does anyone know what the problem could be?
Any help would be appreciated. Thanks .
