Mon, Jan 13, 2:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Overrun by my Runtime
Nightmage ( ) posted Tue, 26 June 2007 at 12:07 PM · edited Fri, 29 November 2024 at 5:02 PM
Hi folks,
I hope someone can help me out here. I use poser 6 still and my runtime is out of control. I’m spending all my time trying to find this mat pose, or that prop, or this figure, buried in all kinds of non descriptive names. I end up with dang little time for making the art.
 I would like to be able to move the folders around to make things easer to find but I’m not sure what can be moved around safely. Is there a utility that lets you safely organize your runtime or is there a guide to what folders can safely be moved?
Thanks for any help.
alpha117 ( ) posted Tue, 26 June 2007 at 12:32 PM · edited Tue, 26 June 2007 at 12:32 PM
Hi Nightmare. I had the same problem until i Split my runtimes into figures, so each figure has its own runtime. ALso I use this from HogSoft, makes life so easy, you will spend more time 'Posing' than looking for MATS etc.
Here is the Link
http://www.hogsoft.com/products/product_info.php?products_id=49
Any more info tat you require then let me know
zulu9812 ( ) posted Tue, 26 June 2007 at 12:32 PM
The base folder structure for a runtime folder is as follows: Runtime ---------libraries ------------------Character ------------------Face ------------------Hair ------------------Hand ------------------Material ------------------Pose ------------------Props ---------textures Poser 6 and 7 support sub-folders. So, for example, you could further break the Character folder down with several sub folders, e.g. Runtime ---------libraries ------------------Character ----------------------------Figures ----------------------------Base Clothing ----------------------------Historical Clothing ----------------------------Sci-Fi Clothing ------------------Face ------------------Hair ------------------Hand ------------------Material ------------------Pose ----------------------------Clothing MATs ----------------------------Eye MATs ----------------------------Hair MATs ----------------------------Poses - Animated ----------------------------Poses - Static ------------------Props ----------------------------Armour ----------------------------Firearms ----------------------------Headgear ----------------------------Melee Weapons ---------textures That should help you organise your runtime. Also, I suggest multiple runtimes.
kalon ( ) posted Tue, 26 June 2007 at 1:17 PM
Nightmage,
You can move library files to different subfolders that make more sense to you, as long as you remain within the same runtime. Because it is the same runtime, it will still point to that runtime's specific geometries folder (CR2, some HR2 and PP2) and that specific runtimes textures folder. Remember that CR2 can only be read in the figures library, PP2 in the props library and so on. If for instance you move a file with the CR2 extension to your props folder it will not even load into your library palette.
It's only when you start to move things from one runtime to another runtime that you will run into trouble. The CR2 (or PP2/HR2) will be looking for its OBJ file in this new runtime's geometries folder, unless you edit the CR2 to point to the new runtime, the same is true for texture files.
There are utilities (and Hogsoft's Correct Reference is one of them) that allow you to change from relative to absolute references within your files. But as it stands, most items default to using a relative path.
kalonart.com
thefixer ( ) posted Tue, 26 June 2007 at 1:19 PM
Yep, I use sub folders which are easily navigable using the small black triangle in top right of your library.
Whatever you do, don't rename or move any of the top level folders!
Others use multiple runtimes but on a persoanl level I found that unsatisfactory and much prefer sub folders!
Injustice will be avenged.
Cofiwch Dryweryn.
Nightmage ( ) posted Tue, 26 June 2007 at 3:08 PM
Thanks for the info all.  Just knowing what folders are safe to move and rename helps a lot.  I will have to check http://www.hogsoft.com when I get home, for some reason it is blocked from my work location.
SamTherapy ( ) posted Tue, 26 June 2007 at 3:59 PM
I'm with thefixer on this one.  I have one colossal Runtime with lots of sub folders.  Each to their own, though.
Acadia ( ) posted Tue, 26 June 2007 at 4:59 PM
infinity10 ( ) posted Fri, 29 June 2007 at 9:11 AM
I use Advance Library abd P3DOexplorer to help see n locate stuff.  Poser_icon helps too.
Eternal Hobbyist
bagoas ( ) posted Fri, 29 June 2007 at 12:14 PM
Same as infinity10 here. Using P3dO. Great app., that shows dependencies and kicks library items into your Poser scene. Can surely recommend it.
B.
