Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 02 11:12 pm)
I don't have Propack, so I can't test this, but I'd have thought it ought to be possible to install V4.1 into it, provided you are putting it into the directory that actually contains POSER.EXE. You get the same message at any release of Poser, if you try to put V4.1 into a different directory. V4 and V4.1 do, however, have features which aren't guaranteed to work at a lower level than Poser 6.
The ProPack doesn't support multiple external runtimes so you have to install to the main Poser Runtime. The installer will do the work for you. There are, however, many features of V4 and 4.1 that simply will not work in anything lower than P6 so having V4 in the ProPack is, to me, a waste of $$
Hugz from Phoenix, USA
Victoria
Just point the installer to your Poser directory and it will do the rest. On my system, Poser is located at "D:Program FilesCurious LabsPoser (5 & 6)" but your installation will be different. I don't have P4 or the ProPack installed any longer since I got P7 and I don't support anythin below P5 for my products any longer.
Victoria
V4 works properly as is only in Poser 6 and up. you can make her work without those warnings in Poser 5 but it involves using a text editor on the cr2 and all the files in the !DAZ/Victoria 4 folder, (you have to change the version number). as they are all set to Poser 6. I don't believe you will get her to work 100% in P4 not sure about ProPack.
cant install v4 into poser 4 propak?comes up with message when using poser tm files must be installed in same dir as exe file,wont install same for morphs etc.what is poser TM?WILL V4 WORK IN POSER4 PROPAK-HELP.
