Wed, Nov 27, 5:53 AM CST
Subject: Shadows in Poser
PixelPusher2004 ( ) posted Mon, 02 July 2007 at 7:09 PM · edited Wed, 27 November 2024 at 2:53 AM
in Poser 4  or   Poser 5, is there any way to render a shadow on an "invisible" ground?
(for example) I want to render a horse running, using an AVI background I rendered in Bryce( rather than export the horse into Bryce)    Unfortunatly, when I do this it looks bad because there is no shadow under the horse...I don't want the Poser ground plane to show, just the shadow.
Thanx in advance
SamTherapy ( ) posted Mon, 02 July 2007 at 7:22 PM
Not in Poser 4 but there's a real simple shader technique to work in Poser 5.  Poser 6 has it built in, so probably Poser 7 does, too.
Gimme 5 minutes and I'll dig out the shader you need to do it.
PixelPusher2004 ( ) posted Mon, 02 July 2007 at 7:42 PM
Thanx...would be appreciated!!
pakled ( ) posted Mon, 02 July 2007 at 8:10 PM
You can put a primitive cube under everything, and that can work ok (just did it with my last pic). You can texture it with whatever materials are in Poser.
SamTherapy ( ) posted Mon, 02 July 2007 at 9:19 PM
A litle later than expected but here is the shader, as promised.  This will work with any surface.
PixelPusher2004 ( ) posted Tue, 03 July 2007 at 5:46 PM
Thanx !!   Had to go to bed, just got home from work and tried this....I never would've figured that one out myself--been trying for days!
    This will come in EXTREMELY helpful    thanx again!
SamTherapy ( ) posted Tue, 03 July 2007 at 7:12 PM
You're very welcome!
IMyself and another Poser user - who's name escapes me momentarily - developed an extension of this which allows you to throw reflections onto an invisible surface.
I'll post that one asap.
