Fri, Feb 7, 7:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Is there a way...
Wild_Dog ( ) posted Tue, 10 July 2007 at 11:50 AM · edited Fri, 07 February 2025 at 7:07 AM
to have a light prop light up everything in a scene. I was using taruru's school hallway prop, but no matter what I use, it still shows only darkness inside the hallway.
Miss Nancy ( ) posted Tue, 10 July 2007 at 12:31 PM
put a point lite inside the prop. uncheck "cast shadows" for the prop. set prop diffuse and alternate diffuse channels to lite colour.
wdupre ( ) posted Tue, 10 July 2007 at 12:38 PM
if you are trying to use infinate lights for an enclosed space you won't get good results, you have to use point or spot lights with their origin within the space as Miss Nancy said.
bagginsbill ( ) posted Tue, 10 July 2007 at 1:35 PM
Almost right. You can use infinite lights if you tell the prop that has the walls to not cast shadows.
Still, that won't get you realism, it will just get you a lot of light. For realism you do want lights in the room.
geep ( ) posted Tue, 10 July 2007 at 1:43 PM
Attached Link: "How To Make A Shadowbox" another fantastic Notebook from Dr Geep ... ;=]
Or, you could just make a "Shadowbox" and play with it ...  heh, heh. ... ;=]
The class (in progress) is in Room 202 at the "U" ... Poser U, that is. :blink: ___ HUH?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
