Sun, Nov 10, 5:39 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 11:21 pm)
Subject: zero params
psnoobie ( ) posted Wed, 11 July 2007 at 8:45 AM ยท edited Fri, 20 September 2024 at 6:39 AM
I have INJection Pose Builder from daz3d. I use is to create character face morphs and it works perfectly. When i create the face morphs in poser 7, i use victoria 4.1, with morphs++. I click on Body Part>Head and then using the params to create the face morph. I load the new face to the expression library, and then create the INJ and REM files from that face using IPB. When I go back to poser the face INJ and REM are in my library as they should be. If i load victoria 4.1, then load the INJ, the face changes the way it should. that part works great. My question is this; When I check the params of the new face they read the same way they did when i created the face. Is there a way to do this whole process so that the dial read zeros when the INJ is applied? I hope i explained this right.
psnoobie ( ) posted Wed, 11 July 2007 at 9:12 AM
I sorry for replying to my own thread. I just found out how to use "spawn morph target" Now how can I use IPB to create the injection morph so that just the morph param is there when i load the INJ in poser?
psnoobie ( ) posted Wed, 11 July 2007 at 12:12 PM
nevermind. i found my solution. thank you anyway
