Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
I have INJection Pose Builder from daz3d. I use is to create character face morphs and it works perfectly. When i create the face morphs in poser 7, i use victoria 4.1, with morphs++. I click on Body Part>Head and then using the params to create the face morph. I load the new face to the expression library, and then create the INJ and REM files from that face using IPB. When I go back to poser the face INJ and REM are in my library as they should be. If i load victoria 4.1, then load the INJ, the face changes the way it should. that part works great. My question is this; When I check the params of the new face they read the same way they did when i created the face. Is there a way to do this whole process so that the dial read zeros when the INJ is applied? I hope i explained this right.
