Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
But. . . I just tried it again attempting to use multiple groups from another package, through UVMapper with only those two settings and I get the same error. So. . . am I to assume that you can only have one image per object? That doesn't sound right. . . I thought I read a tutorial in the manual that allowed you to create other groups. . . Sheesh. . . I wish the error message gave me more information. I don't even know what I'm doing wrong. :-/
You should be able to use more than one image per object...you can have one per material (usemtl) actually. Normals and UVMapper Regions shouldn't cause any problems either because Poser doesn't even read those (at the same time, Poser doesn't read those so I generally delete them from my object to cut down on file size).
I thought maybe something else was in play, but it doesn't sound like it now. I'm now thinking that maybe your obj plug-in is corrupt. You may wish to manually delete it and reinstall Poser (after backing up custom items first to be on the safe side).
Attached Link: Here it is without any textures. Just color.
I have been trying to import a model into Poser with UV coordinates from UVmapper. Each time I try, poser gives me a message saying "Error in plugin FFObj.arp. The model loads into poser just fine before I try and give it UVs. . . Any suggestions? I'm using Poser4 with the Pro pack on Windows98.
