Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
Before P7 Sr2 (I have not tried this since I upgraded) when you save a new figure or .obj file on a Mac it places in the root runtime using windows directory structure or / instead of :. You get some really really long file names as a result that include the / in the file name. Then you have to go back and place the .obj file where it needs to be and then edit the cr2. Not related to your problem it sounds, but others might have the same issue I had. Poser for some reason seems to place things were they should not go, at least on a Mac under P7 SR1.
Gary
Hi All,
I loaded up P7 today and went to open recent files and, nothing there!!! Have I lost all the work I'd done recently? I've done a search for the filename of the scene I was working on but onlt found shortcuts to the files!? So have they gone? Where does P7 save my work?
Hope someone can shed some light
Rob
