Wed, Feb 5, 10:28 AM CST
Subject: Starfield question.
Angel_Natavi ( ) posted Sun, 15 July 2007 at 1:52 AM · edited Wed, 05 February 2025 at 10:21 AM
Alrighty then.  Yet another question in Bryce.  I am a scifi nut.  As such, I like to make a lot of space battle scenes.  Unfortunatly for me, whenever I try to do something complicated, with a lot of lighting effects and lasers and engine glow, the program freezes on me and crashes.  Now, I don't have photoshop, so making it piece by piece is out of the question for me.
And before anyone asks, my virtual memory is already at the highest it can go.  Now, at maximum, I have been able to get three detailed ships into the picture.  One fighter, one smaller heavy ship, like a tug sized one, and a super sized one.  I have been able to get these into the program and start rendoring, before it crashes.
Any suggestions on what to do to stop the program from crashing?  Cause it happens quite a lot with me, despite whatever failsafes it may have.
In order to go forward, one must often times look to the past.
RodsArt ( ) posted Sun, 15 July 2007 at 5:10 AM
Render to Disk will cut down on GUI taxing, so test your image first with a smaller res render, change the image render size(save), and Render to disk (Do not save the file when exiting Bryce). (faster too)
Cut down on reflective, glass, and high-res textured objects.
Volumetric Mats are expensive too.
Save,Save,Save, using altered file names....file001, file002, file003, etc
A starfield can be accomplished using a jpg(made in Universe Image Creator) applied to a sphere or 2D primative with Trans map set.
Also, an alternative to Photoshop is Project Dogwaffle, It's FREE, and from what I've read & seen, is a decent piece of artware.
Good Luck
Oh, btw
If you're still not into post work, you can render a scene with low res materials on your objects, change the materials, and then Spray Render those changes. It can be time consuming though.
___
Ockham's razor- It's that simple
Angel_Natavi ( ) posted Sun, 15 July 2007 at 9:23 AM
Hmmm...
Thanks.  I'll try that.
electroglyph ( ) posted Sun, 15 July 2007 at 9:28 AM
When you render to disk also remember to change the render name. If the name of your original file is "spacebattle" add something to the default name like "RDspacebattle" for render to disk, or "spacebattlebig". If you render to disk and make a big bitmap with exactly the same name you will overwrite the default preview image for your bryce scene. The next time you open the file bryce will try to load this large file. If you are already pushing your memory you could find that you cannot open bryce again without crashing. All is not lost, even if this happens you can just rename the bitmap after the fact. Bryce won't be able to find it and will make a new preview image.
Read the making of siege by flak. http://www.3d-digital-wasteland.com/tut_siege.html  You can render ships and masks one at a time in Bryce and apply them to 2D plains without buying photoshop or other image tool. This will allow you to get many more ships into your render.
Angel_Natavi ( ) posted Sun, 15 July 2007 at 9:32 AM
@_@  Ahh!  Yes!  And I know exactly how to do that too!  Thanks!
electroglyph ( ) posted Sun, 15 July 2007 at 9:37 AM
Are you using visible light for lasers? This can be a real memory and processor hog. It usually doesn't work out that great anyway. Beam weapons can be made on 2d surfaces. Since you don't have any photo tools here are two masks you can use. The first is a photon.
electroglyph ( ) posted Sun, 15 July 2007 at 9:38 AM
Here's another for lasers.
electroglyph ( ) posted Sun, 15 July 2007 at 9:44 AM
Save these two images on your hard disk. Go into the create menu on Bryce and click the leonardo 2D object icon. This will create a 2d object that has the same width to length ratio as the image you are using to create it.
electroglyph ( ) posted Sun, 15 July 2007 at 9:49 AM
Click on an empty box on the menu that shows up to highlight it red. Load the mask into both the first and second windows. The second window does the part of making the object visible or invisible. White = solid, black = invisible, gray is somewhere in between.
electroglyph ( ) posted Sun, 15 July 2007 at 10:05 AM
When the object comes up click on the M and the materials will come up. Kick the sliders for diffuse and ambient all the way up to 100. Whenever both of these added together is greater than 100 the object will appear to give off light.
Change the colors for the diffuse and ambient settings by clicking on the dots next to the sliders. If you hold the "Alt" key while clicking you will bring up the better color wheel for a greater control.
Click on the down to the right of the sliders area and to the left of your triple lasermask material box to bring up the pull down menu. Because it pops up and hides your lasermask material in the "A" position I made a composite out of two images. When the menu comes up the "Blend Transparency" should already be checked. Click on the checkmarks in front of the words "Cast Shadows, Receive Shadows," and "Self Sadows" to turn these off.
electroglyph ( ) posted Sun, 15 July 2007 at 10:08 AM
The resulting object looks like a beam and brighter stars will shine through the edges. You can even rotate the laser shot to give a sense of perspective
pakled ( ) posted Sun, 15 July 2007 at 11:02 AM
Attached Link: Celestia
good to know...even us old hands can learn something.
Another thing you can do (quick fix), is use the Starfield sky, turn up the number of stars, and turn down the intensity (makes the individual stars smaller). I cheat using a magazine copy of Mojoworld (the irony of using a landscape program for it's skies isn't lost on me..;)
Universe if from diard software, if you're looking for it.
There's another program called Celestia, haven't used it, but it does skies.
can't have too many space pics..;)
dvlenk6 ( ) posted Sun, 15 July 2007 at 11:12 AM · edited Sun, 15 July 2007 at 11:14 AM
The Bryce starfield star's size is dramatically affected by the FOV of the camera. The higher angle of FOV, the smaller the stars are; but you get more distortion (stretching) on the edges of the picture.
I've had more luck with image planes or domes/spheres for starfields.
EDIT - Camera's scale affects the star sizes too.
Friends don't let friends use booleans.
thlayli2003 ( ) posted Sun, 15 July 2007 at 12:36 PM
Since you don't have photoshop get the GIMP.  It's free and works great!!
Celestia makes great starfields but the pics need to be edited.
Angel_Natavi ( ) posted Sun, 15 July 2007 at 2:59 PM
Hmm....  So 2d pics for laser effects work better than 3d primatives?  Hmm....  Sounds interesting.  I'll have to give that a try.
danamo ( ) posted Sun, 15 July 2007 at 3:53 PM
One other piece of advice: if you are importing a 2d pic as your star background be sure to turn off cast, receive, and self shadows in your material options. If you don't do this you may get very odd shadows on your background when you light your ships or planets.
pakled ( ) posted Sun, 15 July 2007 at 8:45 PM
another thing is that I've imported pictures, but they come in as 1 Bryce unit (like everything else...sigh..;)  stretching them reveals a wealth of problems..;)  I'm sure there's a better way of doing it, so if anyone wants to chime in on how to do that...;)
danamo ( ) posted Mon, 16 July 2007 at 2:39 AM
Attached Link: Bryce nebula example
I thought I would recommend some of Bryce's volume nebula mats as well. I arranged my spaceship models in front of  the camera, slightly tweaked one of the nebula/nova presets, put it on a sphere primitive in front of my 2D backdrop and rendered. I liked the way it seemed to add implied depth to the scene without postwork. Please forgive the overlit ships,lol.
electroglyph ( ) posted Mon, 16 July 2007 at 6:48 AM
I'd like to point out one thing I didn't do and another thing that danamo did when doing space battle scenes.
I forgot to turn gamma correction off. With gamma correction on if you turn up the light on the scene gamma correction will turn tthe light back down for you. The beams look much brighter with gamma correction off.
danamo put lights at the actual points where the beams were coming out of the ships. If you are going to 2D or postwork lights having a beam shine on something it gets near to makes it look more realistic. It's a touch people often forget when doing postwork effects. Well done!
Rayraz ( ) posted Wed, 18 July 2007 at 8:08 PM
You should work smart with lights. Use limited ranges for lights, dont fill ur entire laser-beam with loads of lights, dont use soft shadows unless the effect really visible ánd neccesary.
For the lasers themselves, using 2d planes with images of laser effects on them is much faster then using complicated bryce textures and lights or even volume textures and stuff like that. Even if you dont have photoshop you probably should be able to make something nice in something freeware like the Gimp or something similar. All this will speed up your renders and most likely make things less heavy on ur system, which might well avoid crashes.
(_/)
