Fri, Jan 3, 7:15 PM CST
Subject: Lights
mhscspo ( ) posted Mon, 16 July 2007 at 8:20 PM · edited Fri, 03 January 2025 at 7:10 PM
Has anyone ever done lighting effects with a police car to make them flash alternately?
I tried to do this without any success, I used the point light and the spot light but I couldn't see the results after the rendering, any help would be greatly appreciated.
geep ( ) posted Mon, 16 July 2007 at 8:45 PM
You could ...
Animate the lights using the "Constant" function and turn each light ON then OFF alternately.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
mhscspo ( ) posted Mon, 16 July 2007 at 9:40 PM · edited Mon, 16 July 2007 at 9:42 PM
Thanks I will try that... which lights would be better to use, the point or the spot light?
by the way I like your Poser University...
geep ( ) posted Mon, 16 July 2007 at 9:51 PM · edited Mon, 16 July 2007 at 9:53 PM
I would use a Point light inside the physical light (object) on the police car and
turn OFF (uncheck) "Casts shadows" for the physical light (object(s)) on the police car.
😄 Glad you like the"U" .......... it's a work in progress ... ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
SYNTRIFID ( ) posted Tue, 17 July 2007 at 7:56 AM
Point lights flashing as the good doctor mentioned would do the trick.
If you want a really dramatic animaed effect you can use spot lights and rotate them alternately, like when one is at y rotate 0 position, another is at y rotate 90.
Actually I would parent them to the physical light objects and rotate those physical objects for the proper look.
The moving shadows produced can give an added dramatic effect to a crime scene animation for example.
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
geep ( ) posted Tue, 17 July 2007 at 8:06 AM
@ SYNTRIFID
Good suggestions ... perhaps a little more difficult to implement but certainly would provide much more dramatic shadow effects in the scene.
Summary ============================================
Blinking Lights - Use Point lights and turn on/off
Rotating lights - Use Spotlights as suggested by SYNTRIFID
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
gmadone ( ) posted Wed, 18 July 2007 at 7:02 PM
There are a variety of nodal solutions for flashing lights, this is probably the simplest.  The rate is controlled by value 1 of the sin node. This is set to change every 2 frames. Flip the step for the other light. (default) You can use the same function on the ambient value of a prop to make it flash. (Just in case we are talking about alternating headlamps instead of alternating lights)
