Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 31 9:20 pm)
I would use a Point light inside the physical light (object) on the police car and
turn OFF (uncheck) "Casts shadows" for the physical light (object(s)) on the police car.
Glad you like the"U" .......... it's a work in progress ... ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Point lights flashing as the good doctor mentioned would do the trick.
If you want a really dramatic animaed effect you can use spot lights and rotate them alternately, like when one is at y rotate 0 position, another is at y rotate 90.
Actually I would parent them to the physical light objects and rotate those physical objects for the proper look.
The moving shadows produced can give an added dramatic effect to a crime scene animation for example.
Hey! His nose is dry! ... Someone should lick it, just in case. - Diego
@ SYNTRIFID
Good suggestions ... perhaps a little more difficult to implement but certainly would provide much more dramatic shadow effects in the scene.
Summary ============================================
Blinking Lights - Use Point lights and turn on/off
Rotating lights - Use Spotlights as suggested by SYNTRIFID
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Has anyone ever done lighting effects with a police car to make them flash alternately?
I tried to do this without any success, I used the point light and the spot light but I couldn't see the results after the rendering, any help would be greatly appreciated.
