Sat, Jan 11, 4:03 AM CST
Subject: Light gels making them
JackieD ( ) posted Wed, 18 July 2007 at 6:44 PM · edited Sat, 11 January 2025 at 4:02 AM
How do I  make a light gel from a b&w image, or  how do I make my o wn b&w .mat file to use as a gel? (Vue6)
BAR-CODE ( ) posted Wed, 18 July 2007 at 6:51 PM
you can just ad a image to the light gel... no need to make it a mat file..
I used the new R'O logo as a gel in one of my last images ...
Works  perfect !!
http://www.renderosity.com/mod/gallery/index.php?image_id=1481615
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
JackieD ( ) posted Wed, 18 July 2007 at 7:18 PM
Thanks! I'll try it out.  Great image btw.  What did you use to get the firey bits?
BAR-CODE ( ) posted Wed, 18 July 2007 at 7:27 PM
The fire bits are in the NEW logo of this site...
Chris
Chris
My Free Stuff
JackieD ( ) posted Wed, 18 July 2007 at 7:49 PM
It's not accepting either .bmp or .jpg.  What file format should I use?
BAR-CODE ( ) posted Thu, 19 July 2007 at 9:18 AM
Yes it does ... your doing something wrong i think..
Remember to click the mapped picture option.. otherwise its looking for MAT files..
Chris
Chris
My Free Stuff
bruno021 ( ) posted Thu, 19 July 2007 at 4:33 PM
First you need to looad one of the gels from your collection, then right click the sphere to edit the function,  then replace the procedural function by a bitmap node, and finally, load in the bitmap you want to use;
You'll need to set the mapping mode to vertical.
andrewe_665 ( ) posted Thu, 19 July 2007 at 7:25 PM · edited Thu, 19 July 2007 at 7:29 PM
never thought of using a picture for a gel I like it
JackieD ( ) posted Fri, 20 July 2007 at 5:29 AM
Thankyou, it worked!!!
I want to make a gel out of the tree's shadow.  Is it possible to render only the shadow and not the tree itself?
Thanks...
rigul64 ( ) posted Fri, 20 July 2007 at 12:20 PM
Yes, in the Advanced material editor check "Only Shadows". The object will not render but the shadow  it casts will.
Rick
JackieD ( ) posted Fri, 20 July 2007 at 8:47 PM
I had been looking in the wrong place (in render settings)..Thanks.
