Wed, Nov 20, 2:46 AM CST
Subject: P7 RIB Export
Kaji ( ) posted Sat, 21 July 2007 at 1:31 AM · edited Wed, 20 November 2024 at 12:03 AM
I'm not sure where to ask this... but has anyone gotten this to work with 3Delight? I just tried it and got a whole bunch of errors, not sure what they mean.
Rendering Test.rib ...
3DL ERROR P1101: [C:/Projects/Graphics/Poser Scenes/Test.rib:8]: floating-point number expected instead of '['
3DL WARNING: [C:/Projects/Graphics/Poser Scenes/Test.rib:8]: Skipping to next RIB call ...
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Ka
3DL WARNING: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Skipping to next valid RIB token...
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Kd
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Ks
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: roughness
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: P
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: N
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: st
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: identifier
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: shadinggroup
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Hip
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: smooth
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rh
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: null
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: paintedplastic
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: texturename
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: C
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Abdomen
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Chest
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Neck
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Head
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: plastic
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rEye
3DL ERROR P1098: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: ']' expected to mark end of array
3DL WARNING: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Skipping to next RIB call ...
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: jpg
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lEye
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: upperJaw
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lowerJaw
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: tongueBase
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: tongueTip
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Right
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rThumb
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rIndex
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rMid
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rRing
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rPinky
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: Left
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lThumb
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lIndex
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lMid
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lRing
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lPinky
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: rToe
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: lToe
3DL ERROR: [C:/Projects/Graphics/Poser Scenes/Test.rib:3253]: Invalid id: ootshigi
Paloth ( ) posted Sat, 21 July 2007 at 1:35 AM
Is that the Daz Studio rendering engine? You'd be best off contacting the Daz technicians via e-mail.
Kaji ( ) posted Sat, 21 July 2007 at 1:40 AM · edited Sat, 21 July 2007 at 1:41 AM
No, it's the actual 3Delight engine from dna research. :)
http://www.3delight.com/en/
nruddock ( ) posted Sat, 21 July 2007 at 4:53 AM
Attached Link: http://www.keindesign.de/stefan/poser/poserman.html
You might try the script that stewer wrote in case it does a better job, otherwise it would seem like a bug report is in order.
replicand ( ) posted Sat, 21 July 2007 at 10:30 AM · edited Sat, 21 July 2007 at 10:32 AM
I dabbled with this a wee bit. I don't have a definitive answer but hopefully I can point you in the right direction, although as mentioned Stewer is the guy.
If you've spent a great deal of time creating these killer skin shaders, you will be disappointed to find that a sucessful 3Delight render from a Poser RIB export has no materials and is all white. At that time I didn't have an external material editor, which you will need to create materials and connect them to items in your exported RIB files.
The first nine lines are material attributes, and the next several lines are the zones that they're connected to. To really get this, you will want a pedestrian knowledge of C and a copy of Advanced Renderman, ISBN 1-55860-618-1.
Kaji ( ) posted Sat, 21 July 2007 at 10:33 AM
Ahh... ok. I was just going to email e-frontier support about this!
Thanks for the tip.
replicand ( ) posted Sat, 21 July 2007 at 10:36 AM
No prob.
