Forum Moderators: RedPhantom
Try my Hansel and Gretel scripts. Hansel lets you draw a real-time
path, with stops and speed changes where you want them .. using a map
as background if desired. Gretel then applies the motion to a chosen object.
You could then apply the Steering script to the vehicle to make it
face the proper direction.
My python page
My ShareCG freebies
Thanks. sounds helpful. I'll try and give it a shot, although I don't know anything at all on how to utilize a script. I don't understand the procedure. any step by step on this? I'm assuming i take the .py scripts and drop them in the python scripts folder in my runtime. after that..........?
thanks a millon for any more help on this, I really want to pull this off. Eddie
This does come with quirks, for want of a better word. for instance,the object does follow the path you draw . but too much in my opinion. unless it is a prob on my end, a vehicle does not travel the path smoothly. instead it follows EVERY little jagged edge of
the line. ??????
Another BIG issue I have is, after having removed the hansel and gretel folders and trash them, I get a window prompting me to "locate cameras and lights" every time I start Poser.
Ockham, any help here?
I remember seeing it done using a walk path and walk designer but it was too confusing.
I don't read or write code and i'm not sure how to parent the car to anything without it looking like its having a seizure. any help is always appreciated. Ed
