Mon, Nov 25, 6:39 PM CST
Subject: Any ideas what would cause this?
Melory ( ) posted Sat, 21 July 2007 at 10:53 AM · edited Thu, 25 July 2024 at 7:29 PM
So I'm trying to use harlequin goth, the A3 version.   Everything works great except for the socks.  I load the socks, it says they are there but I can't see them.  In the material room it says it's there but even after I render the screen is totally empty.  Any ideas?
Visit My Blog!
Dajadues ( ) posted Sat, 21 July 2007 at 11:31 AM · edited Sat, 21 July 2007 at 11:37 AM
Sounds like you're missing files. Did you check the folder manually to see if the socks are there? Not Poser program but the actual folder the socks are in? I always check the folders to make sure the files are all there after installing. Or, the files could be misplaced & not in the right folders.
LostinSpaceman ( ) posted Sat, 21 July 2007 at 11:58 AM · edited Sat, 21 July 2007 at 12:01 PM
This happens when Poser loads  the wrong geometry file for a figure. You might have two different OBJ base files with the same name, probably socks.obj. Poser will load the first one it finds and if it's the wrong one, you'll get this invisible figure problem a lot. This is why file naming and placement is such an important thing for merchants and freebie makers to pay attention to.
To fix it, you first have to find the correct OBJ file. Then Edit the CR2 to make sure it's pointing to the correct directory. Poser checks that directory first and then starts searching for the file elsewhere if it's not found where it's supposed to be. It will then grab the first correct filename it finds even if it's not the right file.
Melory ( ) posted Sun, 22 July 2007 at 12:56 AM
Thanks for the help but neither of those was the issue.  I'm not missing any files and the obj has a unique name and it's in the right place and the cr2 is pointing towards that.
Visit My Blog!
Dajadues ( ) posted Sun, 22 July 2007 at 7:51 AM · edited Sun, 22 July 2007 at 7:52 AM
Can you post a screenshot so we can see the error??
